First After market air cooling product to come available for the GT is this Thermalrights HR-03 GT not sure if anyone has them yet let alone in stock anywhere.
This card uses the same PCB as the 7900 series right? Would a 7900GTX cooler fit on this puppy? That would be the best possible cooler I could think of for the 8800GT. Quiet, efficient, dual slot. Anyone know?
From the reports I'm seeing on temps and sound the VF900 is better than the stock 8800GT cooler. The VF900 might be a better choice than the new HR-03 GT depending on your case. The HR-03 GT is certainly bigger (taller) than the VF900. Besides that I dont think the HR-03 is on sale yet. Should be soon though if it isnt.
