Adrian Wong
Hello everyone!
Adrian's Rojak Pot has just posted a short but informative guide on how Chai built his own water cooling system. Unless you can afford the expensive Kryotech solution, building your own water cooling system could be the only way you can get a much better cooling solution than the standard heatsink + fan cooler. Besides, it's much more fun to build one than it is to buy one! 🙂
Here's a clip of Chai's debut water cooling guide - "Many people try to avoid using water cooling in their case because they have a phobia of 'water', that is running water in their system. Instead, most of them opt for heatsink/fan plus peltier. This will bring lower than ambient temperature, but will never come close to sub-zero or even freezing temperature. So, one of the best combination and the most affordable sub zero cooling system will still be the water cooling and peltier combo."
Also, we have an exclusive news bit about ABIT's upcoming VP6 dual-processor motherboard. To read about it, check out the news page (http://www.rojakpot.com)!
Adrian Wong
Adrian's Rojak Pot
Adrian Wong
Adrian's Rojak Pot
