Greetings!
Hoping to get some feedback/experience. I am planning to piece together a DIY NAS device. Ideally, I would like a device/appliance that does nothing but serve files. My current setup at home for file storage is a core 2 quad box that has 2 mirrored arrays via on board RAID. The workstation runs Win2k8 server and also serves as a VMWare Server as well (4 VMs currently), so it's doing quite a bit and as such it is extremely disruptive if I have to reboot this computer for any reason.
I would like to turn this workstation into a VMWare ESX box in order to remove the OS overhead. The file storage would be split off to a new computer/appliance. Since I am doing some home lab stuff with VMWare, I am intrigued by the thought of using iSCSI storage for the VMs, if the storage is protected by RAID redundancy (ESX is very picky about local RAID hardware).
So really, my quandary boils down to, do I buy a case with hot swappable drive bays, a budget CPU/motherboard and a decent RAID controller and then look at possibly OpenFiler as an OS, or do I go with an appliance. The appliance I was looking at that seemed to fit all of my needs was:
http://www.newegg.com/Product/Produc...82E16822122024 (Netgear ReadyNAS Pro). However, the main drawback with an appliance is that you are locked into the hardware and in the case of this specific device, it is incredibly expensive ($1500). The main advantage I can see is that you get decent support and of course, depending on the device, a user community you can get additional support from.
As an aside, has anyone here done much with iSCSI as it relates to running a VM on an iSCSI target versus local? Again, I am mainly looking at this as an option to be able to add more VMs down the road and have the redundant/protected central storage but I imagine there has to be a performance hit running your storage over a network vs. local.
Thanks in advance for any advice/feedback!
