I was planning on upgrading my system after the first of the year. However, my motherboard decided to go south on me Saturday, so I decided now would be a good time to upgrade. So I could do research on the web I threw together a bunch of old parts, surprised a P100 32MB will even run a cable modem.
Previous Setup was:
AMD Athlon 850Mhz (Slot A) - with Approved PSU
Abit KA7 Motherboard
1GB Mushkin PC 133 Ram
32MB GeForce2 GTS
SB Live Value
10/100 Ethernet
20GB HDD
FDD
16X DVD-ROM
16/10/40 Plextor CD-RW
100MB Zip Drive
I plan on carrying everything except the MB, Memory, CPU, & PSU over to the new one. In a few months I will upgrade the Video Card, but until then I plan on running the current GeForce2. I do not plan on overclocking the new setup.
I have spent almost all of my spare time (and some of my sleep time) researching chipsets, motherboards, memory, PSUs, & CPUs trying to decide what to upgrade to. Based on what I have read, and the feedback I have gotten to previous posts, this is what I have come up with, along with a slew of new questions. If you have time, I would greatly appreciate you feedback, and advice.
Thanks,
Jeremiah Puetz
After many hours of research I started typing out what I thought I had it narrowed down to. I had Asus P4PE, Intel D845PESV, and Asus P4G8X-Deluxe. After comparing prices, availability, and vendors. I think I am going to go with the Asus P4PE.
ASUS P4PE/R/L/SATA Motherboard for Intel P4 478 Retail w/ Intel Hyper-Threading Technology, Onboard LAN, Firewire IEEE1394, Serial ATA, SoundMAX Digital Audio System
Specifications:
Supported CPU: P4 Socket 478 1.4 GHz 3+ GHz
Chipset: Intel 845PE
FSB: 533 / 400 MHz
RAM: 3 x 184-pin DDR333 PC2700/PC2100/PC1600Max 2GB
IDE: 2 x UltraDMA 100/66/33
Serial ATA
Slots: 1x AGP-4x 6x PCI
Ports: 1x LPT, 2x COM, 2x PS/2, 1x RJ45, 1x 1394, 4x USB 2.0
Onboard LAN: BroadCom® 10/100 Mbps
Onboard Firewire: IEEE1394 interface
Price $146 @ www.newegg.com
http://www.asus.com.tw/prog/spec.asp?m=P4PE
Now for the questions:
Will I get better performance from installing a single DIMM, or a Pair?
I had planned on installing (2) 512MB DIMMs, if I decide I need more in the future, will it hurt performance to install a 3rd rather than running a pair of bigger ones?
Is Newegg.com a good vendor? I have never heard of them before visiting AT, but they are mentioned all over the boards.
What brand and speed RAM should I purchase, keeping in mind I do not plan on overclocking it?
Mushkin:
512MB PC2700 DDR SDRAM 333Mhz FSB, Unbuffered, 6-layer PCB, rated 2.5-3-3, 6ns DDR333 w/heat spreader $199 (mushkin.com)
512MB PC3000 DDR SDRAM 366MHz FSB, Unbuffered, 6-Layer PCB, rated 2.5-3-3, 64x64 module 32x8 chips Dual bank org. in double sided config. w/heat spreader $199 (mushkin.com)
512MB PC3200 DDR 400MHz FSB, Unbuffered, 6-Layer PCB, rated 2.5-4-4, 64x64 module 32x8 chips
Double bank org. in double sided config. w/heat spreader $235 (mushkin.com)
Crucial:
DDR PC2700 ? CL=2.5 ? Unbuffered ? Non-parity ? 6ns ? 2.5V ? 64Meg x 64 - Guaranteed compatible at $168 a stick (crucial.com)
Corsair:
XMS2700 CL2 DDR333 = Part Number CMX512-2700C2 - $185 w/heat spreader (newegg.com)
XMS3200 CL2 DDR370 = Part Number CMX512-3200C2 - $199 w/heat spreader (newegg.com)
XMS3500 CL2 DDR434 = Part Number CMX512-3500C2 - $216 or $227 w/heat spreader (newegg.com)
Processor:
Intel Pentium 4 2.4BGHz 512K 533MHz CPU Northwood P478 Processor Retail Box $193 (newegg.com)
Power Supply & Case:
I currently have a case and power supply, but since the system is 18-months old, I assume I need a new PSU. So if you have any suggestions on power supplies and/or cases please let me know. There is nothing wrong with the case I have now (except its black and nothing else is), so if I can get a good PSU significantly cheaper than buying a new case/psu, that would be helpful.
Thanks for all the help, plan on ordering everything Friday afternoon.
Previous Setup was:
32MB GeForce2 GTS
SB Live Value
10/100 Ethernet
20GB HDD
FDD
16X DVD-ROM
100MB Zip Drive
Thanks,
Jeremiah Puetz
Specifications:
FSB: 533 / 400 MHz
Serial ATA
Mushkin:
Crucial:
Corsair:
Processor:
