Advice please! Better settings?
Souji4
22
After days of testing I've settled upon 2 stable settings (w/ conservative settings) for my computer, but keep having mood swings as to which one is "better"
2.4C OCed to 2.76
1:1
3-4-4-8
2.4C OCed to 3.0
5:4
2.5-3-3-6
After reading the massive thread on sync vs async, I don't know which one is better...Would the tight timings make up for the "unmeasurable latencies" caused by the 5:4?
orion7144
4,425
2.4C OCed to 2.76
1:1
3-4-4-8
2.4C OCed to 3.0
5:4
2.5-3-3-6
The 2.4C @ 3gig will be faster at everything you do except memory benchmarks. Toms just had a very good article about the new DDR 500 memory and the advantages of the higher FSB.
Souji4
22
Well, I'm not so concerned about benchmarks as I am w/ the "unmeasurable latencies"...... frankly I have no idea what that means and what that translates into in terms of real world performance. I don't do too many things CPU intensive but I want my comp to be very responsive ;)
Souji4
22
I realize that the lax timings of 3-4-4-8 isn't very relevant as TomsHardware's article and Corsair's article have been pushing. But:
"But, as impressively supported by our benchmarks, simultaneously raising both FSB and memory clock speed makes the most sense by far." -Tomshardware
is saying to keep it at a 1:1 ratio....which is why I'm very hesitant to push it to 3Ghz
help me clear my head??!!:confused:
orion7144
4,425
Originally posted by: AkumaX
why dont you show us some benchies w/ both? :p
Here you go! Abit IS7 and OCZ PC3500EL Have benchies for the IC7-G and OCZ PC3700 Gold but they show the same thing. Also I run DC Folding@home and my times are much shorter with the higher FSB since it is CPU intensive. Not to mention decoding is faster as well.
Sandra scores
250MHZ Dual DDR 5:4 divider 3-4-4-7
2477/5691
Combined performace
CPU Arithmatic 14706
Multi 35751
Mem 10500
Net bandwidth 10460
Combined 2890
225mhz 1:1 Dual DDR @ 3-4-4-7
2335/5200
Combined performace
CPU Arithmatic 13305
Multi 32151
Mem 9829
Net bandwidth 10402
Combined 2726
200mhz Dual DDR Street Racer (PAT enabled) Max I could go was about 210mhz
2079/4639
Combined performace
CPU Arithmatic 11902
Multi 28769
Mem 9651
Net bandwidth 10304
Combined 2596
socalvvguy
59
2.4C OCed to 2.76
1:1
3-4-4-8
2.4C OCed to 3.0
5:4
2.5-3-3-6
Just out of curiousity, Which M/B and memory type are you using? Did you have to up the voltage settings for the CPU or memory? Also, do you have the equivalent of "Performance Mode" or "Memory Acceleration Mode" enabled (ASUS M/B options)?
Soulkeeper
6,740
156
i vote for the higher proc speed and tighter mem timings even if it isn't in sync
