Advice on which Sprint Phone I should get. Please help...
OfficeDepotMan
16
Ok, so im interested in getting a sprint phone... I'm looking anywhere from $50-$200... I need internet cababilities and yea... I'm looking for a cell phone with good rep of reception and service... any advice in where i can get one, which one to get... etc.. etc...
Also, personal experience would be great too... thanks
JknowWhat
206
theres the new sanyo 8100 out for 199 i think. it has a built in camera, color screen, and is vision enabled/capable.
GoodRevrnd
6,801
581
A. This doesn't really qualify as general hardware.
B. You started the exact same thread in Off Topic.
corkyg
Elite Member | Peripherals
27,370
239
I have had Sprint phones (3) for two years. One is brand new, and seems to be good value. However - if I were starting out, I would not get Sprint. It has a notoriouisly weak signal in most areas and is very prone to drops. I envy those using Verizon.
bigshooter
2,157
The phone makes a huge difference in holding a signal. The sanyo's especially the new 8100 (which i just bought :) ) get very good signal quality, while samsungs notoriously don't. Try www.phonescoop.com for information, and then www.sprintusers.com. You'll find LOTS of advice there.
