Advice on Water / Liquid Cooling.
WildThane
41
I am wanting to cool my cpu with an CORSAIR Hydro Series H90, what i need to know is will it work in my system the Specifications say Block Compatibility Intel LGA 1155 / 1156 / 1366 / 2011,... the block on my system is 1150, somewhere I read that it was compatable but the numbers say diffrent...??
If this cooler is not an option what others do I have, at this time there is no overclock on the system but will when proper cooling is complet.
system components
Intel Core i7-4770 Haswell
ASUS MAXIMUS VI HERO LGA 1150 Intel
Cooler Master HAF 932 Advanced - High Air Flow Full Tower
krnmastersgt
2,873
1156, 1155, and 1150 while different sockets in terms of pin count utilize the exact same mounting positions as each other. If a cooler is compatible with any of them it's compatible with the others as well.
Also if you don't have a K family processor you won't be doing a standard overclock as non Is are locked. There are ways of course but quite different from the standard everyone else does.
