Advice on some parts for new system?
Hello all looking for advice on building a new system,i'm not interested in sli.
I already have a 7900 GS,Antec Trio 650W,Monitor,Kb,Mouse.Speakers.
I need the rest of the stuff to complete a system,i'm still new to putting systems together but have put several psu,vid,sc etc in.
I want this build to be Intel c2d.
I Have a $700-$750 hundred budget.
Many Thanks
To me, case choice depends a lot too on how you want it to look, so find some others you like as well and compare them.
Here's some good o/c memory with a great price after rebate
Partiot DDR2-800 2GB
For o/c, I'd check out the e6300 or e6400
C2D
I don't know what kind of features you need on a motherboard, but here are a few you can take a look at
Asus P5B-E
Asus P5B-Deluxe
Gigabyte DS3
Also, what about optical drives and HDDs. What capacity would you need for a HDD? Take a look around and throw something together as it'll give a better idea of what all you need and/or are looking for.
Sorry so late to reply had to run to the store for my g/f.
250 gb or 300 gb sata HD with 16 mb cache would be nice,i already have a maxtor 160 8 mb sata but have heard bad things about them i don't know who is king of the hill now last i checked was Seagate i believe?
I forgot to ad i have already optical drives.
The main thing with the cases for me is that the have good vents and fans and cool the system well.
I also had someone recomend this cpu even though it isn't c2d and he said use this untill quadcores come down in price then jump on one.
what the main differences between the c2d and this one again ,many thanks.
Do u think by the time quads are at a good price that there will be a new DDR 3 standard?
http://www.newegg.com/Product/Product.asp?Item=N82E16819116239
Many Thanks moosey u have helped me out a great deal.
Would u happen to know which board has the better onboard sound?
Btw forgot to add i believe ill be using Vista is that matters.
I'm not 100% sure on this one, but I think some people had some issues with the audio on the Asus boards (cracking?). Check the Newegg reviews for that also, they could be helpful in that regard. Someone can correct me on that if I'm wrong though.
Edit: I just put those boards out there as an example too, as those are some I'd consider if I were buying a P965 board and they o/c well. You can go lower in price if necessary.
Ok so now im having trouble staying in my $700-$750 budget range.argggggggg
Where can i cut corners?
Thanks
COOLER MASTER Centurion 5 CAC-T05-WW Black/Silver Aluminum Bezel, SECC Chassis ATX Mid Tower Computer Case - Retail
Item #: N82E16811119077
Return Policy: Standard Return Policy
$49.99
Seagate Barracuda 7200.10 ST3320620AS (Perpendicular Recording Technology) 320GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
Item #: N82E16822148140
Select An Optional Extended Warranty Plan 1 Year Service Net Replacement Plan -- $14.99 2 Year Service Net Replacement Plan -- $19.99
-$5.00 Instant
$94.99
$89.99
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-2GBNQ - Retail
Item #: N82E16820231098
Select An Optional Extended Warranty Plan 1 Year Service Net Replacement Plan -- $39.99 2 Year Service Net Replacement Plan -- $59.99
-$30.00 Instant
$214.99
$184.99
ASUS P5B LGA 775 Intel P965 Express ATX Intel Motherboard - Retail
Item #: N82E16813131030
Select An Optional Extended Warranty Plan 1 Year Service Net Replacement Plan -- $29.99 2 Year Service Net Replacement Plan -- $39.99
$124.99
Intel Core 2 Duo E6400 Conroe 2.13GHz LGA 775 Processor Model BX80557E6400 - Retail
Item #: N82E16819115004
Return Policy: Processors (CPUs) Return Policy
$222.00
Microsoft Windows Vista 32-Bit Home Premium for System Builders Single Pack DVD - OEM
Item #: N82E16832116202
Return Policy: Software Return Policy
$119.99
Subtotal: $791.95
Calculate Shipping
Zip Code: FedEx Express Saver -- $58.46 FedEx 2Day -- $102.48 FedEx Standard Overnight -- $125.94 UPS Guaranteed 3 Day Service -- $25.00 UPS 2nd Day-- $66.90 UPS Next Day Saver -- $81.97 GO
Shipping: $25.00
Grand Total: $816.95
You can trim some money going with an e6300 processor if you're going to overclock and want to go that route. The e4300 is a great chip to o/c as well.
Check out these 2 boards as well, they can save you money. Also, the P5B-E is a better overclocker than the P5B.
Biostar
Gigabyte S3
Anandtech P965 Awards
See how any of this works out
Thanks again moosey,I read that article and was considering those and then i have been hearing these horror stories about the 965 chipset problems with certain kinds of memory and it's kind of hit and miss,do u think the ram i picked would work in those boards u posted?
Many Thanks again🙂
I can't say for sure, but I don't see why not. I'd mainly check some reviews for that and see what they were using. A lot of people use the Corsair as well. You should be fine though I'd think, especially as BIOS' mature for these boards.
