Advice on quet 80mm Fan for my Heatsink
Kebbor
4
hi, I have a Athlon XP 1600 with a Taisol CGK760092 (coperbase) on a ABIT-KR7A-raid mobo
the Heatsink came with a 4800 RPM (21cfm) fan wich I think is Delta with a noise level of 30dB . The noise increase from my previus system was very big (I had a PIII 600mhz)
and is becoming very iritating. So I am thinking on getting a 60mm to 80mm adapter and then by a Panaflo L1A fan with a 24cfm. Will this efficently cool my cpu ?
or will the cooling deefficency coused by the adapter be to large ? my current cpu temp is 46C at idle and 49C at load
or should I by the PAL8045 and change the fan to a Panaflo LA1 ?
any advince would be nice
// Kebbor
ShinSa
744
<< hi, I have a Athlon XP 1600 with a Taisol CGK760092 (coperbase) on a ABIT-KR7A-raid mobo
// Kebbor
an adapter will cost you around 10 bux. For 3 bux more your can pick up a GC68 for 13 bux at casemod.com
This will much better than you using an adapter and having it restrict airflow.
It's just too much money for a piece of plastic.
MoFunk
4,058
// Kebbor
you will really like the Alpha!
The Dancing Peacock
3,385
hey ShinSa, that link goes to some "coming soon" page. I have a similar problem and wanted a cheap solution to it as well. Spending 13 bucks on a fan adapter wasn't worth it. Are you recommending a HSF?
lordbob99
515
hey guys,
if ur looking for the gc68 at case-mod.com, here's a link.
i should be getting mine in the mail either today or tomorrow. from what i've heard so far, it should be a pretty nice sink.
lordbob99
rondeemc
1,216
Vote for the alpha here. Go to svccompucycle and get it for $29.99 and also pickup a few of their adaptors that allow you to run a fan off the PS and still monitor the rpm (only 0.99 each which is a steal). Then go to newegg and get the Enermax manually adjustable fan for $8 plus shipping which allows you to set the fan speed to what pleases you...cause control is a good thing.
svc sale page
