Well, with six of us, we goth the front and back yards done in one day even after sort of a late start.
1. Rotors are fine. Nice thing is not having to have any sprinkler heads in the middle of the lawn for kids or you to stub your toes on.
2. The only difference between cements is color...black, gray, clear. I guess you could use clear if the pipe was going to be exposed and you weren't going to paint it? I went with gray so I could see that I was getting a good application each connection.
3. The trencher is great. It's loud like an old rickety motorcycle and makes a loud clanking sound when the blade starts cutting. There's a half dozen levers, but after a few minutes, you get the hang of it and can dig perfect sized trenches way faster than a team of guys could dig them. It's powered so even going up hill is no problem.
It went pretty smoothly. Project cost me a total of $500 for 2 lawns about 40' x 70'. (the trencher rental would have been another $200+ but it was picked up by my parents as a gift) I don't think I could have gotten a quote for six times that and the end result is exactly as I envisioned. I'm pretty sure I just helped my house appreciate 2 or 3%. All I need to do is finish the electrical...I already have the front zones wired and just need to decide if I link the back to the same timer and run the cable across a very cramped crawlspace or get a separate one.
My advice:
- Definitly rent a trencher if you have anything over a small lawn.
- Knowing your PSI and GPM is necessary for knowing how many sprinkler heads you can fit on each valve/zone.
- Unless you've done it before, you'll probably need to run to Home Depot or a sprinkler supply store at least a few times for miscellaneous parts you'll forget. I did a pretty good job of planning it all out but I did completely forget, amidst figuring out how many T's and L's, to get couplers.
Make sure you have an extra person on hand to make runs or buy a few of everything just in case and return what you don't use. Here's the misc PVC pieces I needed: Slip elbows, slip to female threaded elbows, slip elbows with threaded female side outlet (corresponding 1/2 - 3/4 riser), couplers, slip Ts, slip to threaded male adapter (needed for manifolds), end caps, compression coupler. I also needed a bunch of galvanized steel pieces for the connection to the house water, but that will depend on your house and connection etc.
Anyway, there's the update.
