Advice on Overclocking
rhino19
21
Hi all.
Little background
NF7-s
XP2100 @2.21 Ghz (10.5x210FSB)
corsiar XMS 3500 433mhz ram
1.7 volt CPU 2.8 volt Ram
I was wondering how i could get more out of this proccessor. Ram timings, Cpu multiplier.
What is the most efficent way to overclock and still retain a stable system.
Thanks for any advice
Shimmishim
7,504
you can increase your vcore and up your mult
you can always try 11 x 210 and increase your vcore by .05 to .075 so you'll be running 1.75 to 1.775 which in actuality is somewhere between 1.68 to 1.72 volts due to the fact that the nf7-s undervolts like crazy...
i'm running 11.5 x 210 @ 1.8 volts (1.74 actual)
give it more juice!!!
