Right I've just got a Corsair 900D case to build a custom watercooling loop.
These are the parts I already have:
Everything is in my current air cooled PC bar one of the 690's.
My loop design:
Green arrows are where I'll try to hide the tubing.
Now my questions are:
Finally
The XSPC 690 GPU block is what I was looking at for theGTX 690's. However this has aluminium in. From reading up this seems a really bad idea in a loop?? (All the other blocks listed are copper/plexi. Can someone confirm I shouldn't put aluminium anywhere near this.
Thanks for reading, any advice really appreciated.
- GTX 690 (SLI)
- i7 3770k
- Sabertooth z77 Mobo
- Seasonic Platinum 1000w
- Corsair Vengeance Ram 16GB
My loop design:
- Does this loop look sensible to anyone?
- Should I change the top rad to be a 360 instead of quad?
- Should I use push/pull on the rads (there is space to do that)
- I'm only going to use distilled water but what size tubing should I use?
Finally
