Hi,
I'm building a Pro-Tools Daw (I know that might be irrelevant) and I need some advice on what motherboard to get. The roundups and reviews seem old, probably because I haven't followed hardware for a few years and I don't like to read. Anyways, I want to build the fastest system I can based on a Pentium 4. What's the best motherboard to use?
P.S. If I should go with the 64bit AMD system for some reason speak up. I kind of don't want to for the sake of stability of windows and protools. Is that false?
thanks
thanks
