- May 25, 2025
- 1
- 0
- 6
Hi, I'm looking for constructive criticism and advice on my PC build. I'm not seeking specific purchase offers, I just need help deciding on the components.
Format: mATX or mid tower
Budget for PC: Around 6000–7500 PLN (maybe more if necessary). Translates to around 1400–1800 USD, or more (hard to convert exactly due to cross-border price differences).
CPU and GPU: A good setup at a lower price. Later this year I want to upgrade to RTX 5070 Ti + AMD Ryzen 9 9950X (buying some better AIO now with this upgrade in mind).
Country: Poland
Purpose:
- Games: Rasterized, light ray tracing (maybe). Recording gameplay.
- Creative work: Definitely Photoshop. Additionally, maybe learning modeling in ZBrush and Blender (simple projects). I might try some AI video upscaling in Topaz or DaVinci Resolve.
___________________________________
A. Micro ATX:
- Case: Lian Li A3-mATX wood (370 PLN)
- CPU ooling: ARCTIC Freezer 34 eSports DUO (200 PLN)
- One rear exhaust fan: Arctic P12 PWM PST (26 PLN). No obstructions – priority is low noise level and decent airflow.
- Bottom slim fans: SilverStone Air Slimmer 120 (200 PLN za 3 sztuki). It has higher static pressure than other slim options, which helps push air through the mesh. It's a bit louder, but I can accept that trade-off.
- Power supply: Corsair RM850e 850 W (530 PLN)
- SSD: Crucial T500 1TB (380 PLN). Avoid picking up an SSD with a heatsink from the factory as removing that may void warranty. Motherboard comes with heat spreaders for M.2 SSD's
- Motherboard with USB4: ASUS ROG Strix X870-I Gaming WiFi (1650-1900 PLN)|
^ USB4/Thunderbolt is added because I want a port that allows video/touch/power transmission via a single cable. I use Wacom Movink 13 with stylus and another portable OLED.
- GPU: ASUS TUF Gaming RTX 5070 OC (2800-3000 PLN) or MSI GeForce RTX 5070 12G Gaming Trio OC (2800-3000 PLN)
- RAM: Corsair Vengeance 6000MHz CL30 (504 PLN)
- AMD Ryzen 7 7700 OEM (830 PLN) - 830 PLN
^ Out of the box, the Ryzen 7 7700 trails the 7700X by roughly 3–7% in multi-threaded tests, but enabling Precision Boost Overdrive (PBO) auto closes nearly all of that gap, bringing performance within 1–3% of the 7700X. Applying a –30 mV offset via the Curve Optimizer can yield an additional ~3–4% improvement in multi-threaded workloads while cutting peak temperatures by up to 15 °C, making the non-X model a cost-effective alternative to the 7700X.
Total = ~7490 PLN
Future upgrades (later this year):
- Cooling: Be Quiet! Light Loop 360 (572 PLN). Generally has to be strong enough to sustain things like Blender rendering (sustained high average, and very high peaks).
- GPU: RTX 5070 Ti, something stronger from AMD or maybe RTX 5080 (last one probably unlikely).
- CPU: AMD Ryzen 9 9950X
B. Mid Tower sized:
- Case: Lian Li LANCOOL 207 (423 PLN)
- CPU cooler: ARCTIC Freezer 34 eSports DUO (200 PLN) or Thermalright Peerless Assassin 120 SE (190 PLN). Arctic has much better warranty.
- Top fans: 2 × Arctic P14 PWM PST (64 PLN for 2)
- Rear fan: 1 × Arctic P12 PWM PST (26 PLN)
- CPU: AMD Ryzen 7 7700 OEM (830 PLN)
- Motherboard: ASUS ROG Strix B850-E Gaming WiFi (1471 PLN) or Gigabyte X870E AORUS PRO ICE (1500 PLN).
^ B850-E is more recent and has some AI fireworks. Both have USB4 ports 40 Gbps (Asus has 1, Gigabyte has 2).
Totals = ~7228 PLN
- Cooling: Arctic Liquid Freezer III Pro 360mm (430 PLN). Generally has to be strong enough to sustain things like Blender rendering (sustained high average, and very high peaks).
Country: Poland
Purpose:
A. Micro ATX:
Total = ~7490 PLN
B. Mid Tower sized:
Totals = ~7228 PLN
