About 90 days ago, I got a Western Digital hard drive. That 120 gig one, with the 8 meg buffer.
I'm finally about to install it, now that I've purchased a new computer. (A Dell Dimension 4500.)
Thing is, I lean sort of to the incompetent side when it comes to hardware issues more complex than screwing in a light bulb, so --
1) The drive came without any additional stuff. No manual, no extra hardware, no nothing. Just the drive. Am I correct in thinking that I've got to go and buy some sort of mounting kit, in order to install it in the new computer? If so, any advice/recommendations/warnings regarding this purchase?
2) I've found a couple of websites that explain how to install a new hard drive. It seems straight forward enough. Is there anything any of you would like to emphasize, before I chop a hole in my new computer with an ax, then Krazy Glu the hard drive in place?
3) I'm leaning toward removing the budget 20 gig drive that comes with the Dell, and simply replacing it with the 120 gig drive. As opposed to installing the big drive, using it as my primary drive, and demoting the 20 gig one to secondary status. It just seems simpler to swap one for the other, than to keep both, and it's not like I'm going to need the extra 20 gigs when I already have 120 gigs available. Am I right in thinking that swapping big for small is my simplest option here?
As for the minor things --
4) Are NIC cards essentially "plug and play?" Can I just remove the one from my old computer, put it in the new Dell, and expect it to work?
5) I'm thinking of removing the DVD drive from my old computer and installing that in the new Dell. Any advice?
6) The Dell comes with XP Home. I have a copy of XP Pro. As long as I have the "better" version of the OS, I'd like to use it. Any warnings regarding upgrading from Home to Pro?
Thanks for your time and help.
