Question Advice on how to achieve failover with current network setup
Steelbom
455
22
Hey,
I currently have a residential connection and a starlink connection. I also have a backup 5g sim as well.
I have two switches and another ethernet cable which plug into the router (currently using Netgear Orbi, but switching to Ubiquiti Alien).
I'd like to achieve failover where it uses the residential connection first, followed by the starlink one, and then finally the backup 5g if nothing else works.
Right now, I'm manually switching WiFi or moving ethernet cables around.
I was wondering what the best way to achieve this is?
Cheers,
SB
akugami
6,210
2,551
I'm not familiar with Ubiquiti gear, but a MikroTik router can be scripted to support failover. I actually am using a MikroTik RB5009 in my house. I am not familiar with writing scripts for it, but am planning to learn as I get more free time. There's a very healthy Reddit, and plenty of documentation on it as well as youtube videos.
Out of the box, and with less hassle, you can probably use an Asus router, which has both failover and load balancing built in. I am not familiar with the Asus routers, so I wouldn't know how difficult it would be to set up. Considering Asus router's are mostly a consumer level device, it shouldn't be too difficult.
The link below is to the Asus page with info on both failover and load balancing with an Asus router. You'd probably have to double check with Asus routers suppor this functionality.
It should also be noted that there should be Ubiquiti routers that support dual WAN w/ failover. Again, I am not familiar with Ubiquiti gear.
Reactions: Steelbom
