Originally posted by: Madwand1
Originally posted by: Atheus
I have 2 320GB Seagate drives in software RAID-1 on a cheapo Adaptec card stuck in a 66Mhz PCI slot. This modest bus is able to handle the throughput of both drives absolutely fine, and the drives themselves are able to push as much data as my client's WD Raptor can handle, and stream a movie to the HTPC upstairs at the same time. The (cheap) Pentium-III processors run a LAMP server with a couple of websites, a mail server, and they compile my Linux programs, all while keeping an average CPU usage of only a couple of percent.
Multi-processor 66 MHz PCI = low-end cheap hardware? Maybe it's cheap now because it's obsolete and used, but it wasn't cheap originally. If you're actually saying that your server can sustain 60 MB/s file transfers, then great. Are you? BTW, what are the specs in detail? Perhaps the OP can consider that as an alternative.
Yea, well, that's the point isn't it. Hardware like this is not only cheap becaue it's old, but also reliable, because it was built for server-class machines.
Specs in detail:
- Tyan Thunder LE-T motherboard, serverworks chipset, dual socket 370, I think I got if for about £50 on Ebay. Can't find another second hand one right now, but there's Tyan K7s with similar specs (SCSI, 64/66 PCI, dual Intel LAN, etc) on Ebay USA for like $100. This was the most expensive component.
- 2 ~1Ghz PIII processors at like £10 each. Less maybe.
- 512MB of ECC PC133, maybe £30? £40? Memory is more expensive these days though.
- Fortron Source power supply and HDs, new, you know the prices on these I assume.
So that's a little over £100 on the main system, then like £150 for the drives and PSU, and for that I can take a HD failure, processor failure, and a memory stick failure, without a crash.
I'll measure the actual disk and network throughput if you want, but you'll have to wait, the thing is in bits on the floor. Those old 1U heatsinks are too damn loud and I'm replacing them.
/Edit: I realize this is quite a powerful system - I'm not recommending everyone buys something like this - my server gets more workout than the vast majority of home servers. The point is you can get good performance with old hardware.
