My case is a Rosewill Conqueror and after adding on a Radeon HD 4870 to my rig I have noticed a significant increase in my CPU temp's. Its enough to make previously obtainable overclocks dangerously high.
Specs on rig:
Athlon 64 X2 5000 Brisbane OC to 2.99 GHz on stock fan/heatsink.
6GB DDR2 800
SAPPHIRE Radeon HD 4870 512MB 256-bit GDDR5
Picture of case:
Rosewill Conqueror
A 120mm fan on the side window is the only change I have made to the cooling of the case other then a fan controller.
What can I change in my cooling solution to get the most benefit? I'm willing to do a bit of case modding if necessary.
The front and exhaust fans could be better in my opinion but I don't know enough to say it would really make a difference to replace them.
Thank You
Specs on rig:
6GB DDR2 800
Picture of case:
Rosewill Conqueror
Thank You
