Advice on A+ Study Material
krnmastersgt
2,873
Umm, option C: Mill around Anandtech threads and ask questions when you need to on maintenance.
Personally I think that'd beat any book out there, especially since we give you info based on lots of experience and keep up to date on every component you can think of, a book is published and not re-published due to costs. If you have any questions as of now, make a thread or pm me and we'll get it taken care of asap.
Lifixs
40
Well I have been lurking around occasionally asking questions related to my own problems. When I look at the info covered in the guide by Michel Meyers I feel like I have at least a bit of functional knowledge on most of the things covered, but I know I'm missing the details that I need.
For instance (Ripped from the guide's overview):
* Configure CMOS and BIOS settings - I know mostly the self explanatory parts, allot of terms and concepts elude me. Ex. What actually is the FSB?
* Identify expansion bus slots and install expansion cards - I know only what I have needed to know. Ex. The differance between an AGP slot and a PCI slot. Although other than one being faster than the other I don't know any of the details.
* Work with motherboards, CPUs, and RAM - I know the basic functional aspects. Ex. Why do AMD chips clocked at the same speed perform slower than Intel ones?
* Provide proper power and cooling - I know CPU's need heat sinks and you need a high enough wattage power supply to power all your components. Ex. What are voltages and how do they relate to heat and the reliability of components?
* Install, partition, and format hard drives - I think I know this.
* Install and upgrade Windows 9x/Me, Windows NT 4.0 Workstation, Windows 2000 Professional, and Windows XP - Think I know this.
* Work with portable PCs, PDAs, and wireless technologies - I know very little about PDAs, limited understanding about the rest. Ex. What is the difference between wireless a-b-g-n? Other than speed?
* Install and troubleshoot floppy, CD, and DVD drives - Think I know this.
* Create SCSI chains - I have no idea what this is.
* Install sound and video cards - Think I know this.
* Manage printers and connect to networks - I can't configure a network beyond the default setting. (I can however flash and configure DD-WRT on my router.)
Another thing is that I don't actually know what I don't know. A study guide plus these forums would most likely be the best guide, giving me both a clear trail to follow but also the collective knowledge to pickup from where the book leaves off.
krnmastersgt
2,873
FSB = Front Side Bus, layman's definition would be the speed at which the CPU and RAM communicate with each other via the motherboard.
AGP Bus: No real need to learn about this, it's just there really. It's a dying breed, only found on some older system or very low end motherboards.
AMD Chips: The Intel microarchitecture is different from AMD's, therefore the chips handle data differently, if you head over to the CPUs and overclocking section and make a thread, you'll likely run into Idontcare, who knows pretty much all you'll ever need to know about CPUs and their microarchitectures. Or you could just PM him, whichever suits you. This is far from common knowledge, the info behind this is best suited to electrical engineers.
Voltage: Easiest way to define voltage would be, electrical pressure, like water pressure builds up in a pipe, electrical pressure or voltage can be built up in a circuit to generate a stronger current since it powers over the circuit's resistance to electrical flow.
Increased voltage = more current flow = more heat generated. Metals aren't perfect conductors and therefore waste power generating heat, if you had a cpu and motherboard made out of super-conductors, the closest to 0 resistance humans can create at the moment, then there'd be almost no heat generated, regardless of the voltage/current flow. Heat = enemy of all things electrical, heat causes wear and tear on components and therefore the components need adequate cooling to last longer. The cooler it is, ideally the longer it lasts assuming there are no mechanical or chemical parts on the object. (mechanical as in moving)
Wireless types: It's more of a tech difference, over time better and better routers were developed using different technologies, and were given different names over times assigned via the letters you mentioned. G and N are the most common nowadays.
SCSI: This is only important to RAID configurations if I'm not mistaken.
I suppose you have a valid point on the book, still seems a waste to me though :p I prefer to just get by on the knowledge I have, wait till theres something I don't know and then when I learn about it, get more involved and learn about related tech. Worked well for me so far, also a basic understanding of electricity and circuits explains a great deal to you when you look at all this hardware we discuss, maybe look into that for starters?
Lifixs
40
Thanks, you did a beautiful job of explaining all that. I'm going to look around and see what I can learn but still get the study guide (The free one.).
Slatz
148
Get the free book. And yes you will have to know at least what the acronyms stand for (AGP = Accelerated Graphics Port) also called Advanced Graphics Port. You will have to know different sockets for cpu's etc. You will have to learn old and new hardware. For example what socket will fit an athlon 1200 tbird? Read- read and read. Good luck with it, it really isn't that hard but like I said you will have to learn hardware and what it is for. IRQ's etc.
SonnyDaze
6,867
Originally posted by: Slatz
IRQ's etc.
I took an A+ prep course a few years ago and IRQ's were a big deal. The instructor wanted you to know all of them verbatim. :confused: :laugh: We used an A+ certification book my Mike Myers for the course......that thing is about 3 inches thick. And I never took the exam. :(
pacent
21
I took the test years ago. Some of the questions they ask are stupid and you'll never apply them in real life...things like whats the maximum number of USB devices you can daisy chain together, and how many hard drives can be connected via SCSI (small computer systems interface). You really need to read the book to pass. It does test some real life examples, but those questions are easy.
