Hi, I'm thinking about building a desktop soon for around $1000. I made a thread about a $1000 build back in January, but I want to start a new one for more updated parts recommendations and advice.
old thread: http://forums.anandtech.com/showthread.php?t=2461777&highlight=
Here's my answers to a build q/a:
1. What YOUR PC will be used for: Web surfing, office documents, some gaming, music production.
2. What YOUR budget is: Around $1000
3. What country YOU will be buying YOUR parts from: USA
4. IF you're buying parts OUTSIDE the US, please post a link to the vendor you'll be buying from: N/A
5. IF YOU have a brand preference: Intel cpu, nvidia gpu
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are: maybe my current videocard (740 gt 2gb) for time being, but may upgrade.
7. IF YOU plan on overclocking or run the system at default speeds: prefer default speeds, with option to OC if I want to.
8. What resolution, not monitor size, will you be using? 1080p
9. WHEN do you plan to build it? Within a couple of weeks, if not later.
10. Do you need to purchase any software to go with the system, such as Windows or Blu Ray playback software? Windows 10 pro oem.
I want an i7 cpu, maybe 6700 or 6700k. Do you think that's necessary or should I go with i5 6600k?
