abrilevskiy
Hello,
Could you please help me to find a good upgrade option for the current using Samsung 970 pro?
It is required to increase capacity from 512 (Samsung 970 pro) to 1 TB at least.
I am concerned about new Samsun models due to: TLC memory type instead of MLC, firmware issues and fake drives.
The replacement will be done in Lenovo Yoga 920 laptop with PCIe 3.0 x4. The laptop has some battery issue: Windows booted at a low battery level (for example the laptop was not used for a while) and then the laptop gets powered off by itself without Windows power-off mechanism - so-called hard shutdown - therefore data safety is a priority.
Thank you in advance!
