- Oct 23, 2000
- 9,200
- 765
- 126
I need advice for my low budget "home theater" room.
My wife and girls enjoy having a large screen for playing games and for watching movies and anime. I enjoy it as well, but if I got what I wanted, I would probably be spending a LOT more than the proposed budget for this project, and they use it a lot more than I do since they frequently play games while I am at work.
We currently have a boring Epson PowerLite 99W projector and a 7-foot wide (96-inch diagonal) Da-Lite pull-down screen of unknown model, but it's old enough that it's actually a 4:3 screen that we only pull-down part way to make it 16:9. The front of the projector is 13 feet 6 inches away from the screen. There is room to expand up to a maximum of an 8-foot wide (110 diagonal) wall painted screen which I probably want to do at some point. Distance from the projector to the screen can be reduced by installing a ceiling mount for the projector, but it cannot be increased by more than about 6 inches at most. The room is in the basement and does not have any windows so it's easy to get complete darkness simply by closing the door.
I'm using a multiple input HDMI switch that automatically switches between inputs (multiple gaming systems) and sends the signal to the projector.
The girls are perfectly happy with the mediocre image quality of the Epson projector, but it is starting to die so I have permission from "the boss" to shop around for other options.
Although it drives me nuts, they actually prefer to play games and watch movies only using the built-in speaker in the Epson projector, because external speakers are "too loud" and having to remember to turn them on is too much of a hassle.
Before the Epson, we had an Optoma ML1000 LED projector that I liked for the simplicity and low power use (and low heat production) and not having to worry about replacing the bulb. Brightness was very good, but color quality left a lot to be desired, with far too much red tone. The fact that the Epson doesn't have that red tone problem is a big part of why my girls think it is good enough, but I am hoping to make them say "wow" with the replacement, without making my wife say "wow" with the cost.
So...my goals:
Total cost of less than $1000.
1: A projector that is not loud as it will be directly behind the primary seating area in the room, and that will produce a better image than the Epson at a throw distance of 13.5 feet and screen size between 7 and 8 feet wide (96 to 110-inch diagonal). 4K would be a nice bonus, but is not a priority at all, since most of the content they view is 1080p or lower (anime).
2: A sound bar or surround system that fits within the budget and that will automatically turn on when it receives a signal (or just stay on) to provide better quality sound but that doesn't draw attention to itself by not allowing very low volume levels when desired, and that doesn't take up a lot of space. Something that can take audio directly from the HDMI switch or the projector would probably be the best option for this situation since a separate audio receiver definitely won't fit in the budget. The gaming consoles and HDMI switch will sit on shelves a few feet away from the projector, on the opposite wall from the screen/speaker(s) if that makes a difference in the options.
3: Suggestions for inexpensive wall paint to use for a wall screen that will be as good or better than my current very old pull-down screen. Or we can just keep using the pull-down screen if screen paint will take too much away from the rest of the budget.
So...my goals:
