- Dec 28, 2006
- 3
- 0
- 0
Hello everyone,
I am looking at doing a Core 2 Duo build and I'm looking for some opinions to see if I'm headed in the right direction. I've spent hours searching but I seem to be stuck now. I'm confident my post includes necessary information and I've done days of research so this won't be a "do all the work for me" post.
I have already decided on two components but I'm looking for some guidance on the other parts. I'm just looking at building the box. I already have keyboard, mouse, monitor, speakers etc...
Here are the components I've already got from my last build that I would like to use:
Case: Antec P-160 - the length of the video card is 9 inches and I've measured it has room with some spare for the power cable so hopefully no problem here
PSU: OCZ Modstream 450Watt - this is the part I'm most concerned about. It's above the 400 watt minimum for the 8800GTS and has 26A on the 12 volt, but would like some other opinions
Harddrive: Seagate 7200.10 400GB (SATA)
DVD: Samsung DVD writer (IDE)
Sound card: Sound Blaster Audigy 2 ZS
If these parts won't work for my build I'm willing to throw some extra money at getting something else but I'd like to know if they'll work before I spend time researching replacements.
The parts I'm set on getting:
-Intel Core 2 Duo 6600
-8800GTS based video card (probably the EVGA)
The parts I'm currently stuck on are the motherboard and RAM. Right now the board that most appeals to me is the Asus P5B Deluxe. However, I'm a little apprehensive about another Asus board because my last two (A7N8X-E and K8N) suffer from terrible coil whine. Still I can't see anything comparable that I like. Something with the 965 chipset seems best for me.
Another possibility is the Gigabyte DS3, but I'm not as impressed by it. It is cheaper though I'm still leaning toward the Asus P5B Deluxe.
And that leaves me at RAM which seems very confusing. I think I should go with DDR2 800. Most of the memory threads I read dealt with overclocking so I don't know how that affects me. I don't plan to do any overclocking (though it is tempting and I may want to try it in the future since a lot of people here are big on Core 2 Duo overclocking).
This computer will be mostly for gaming, nothing else that will affect my part choices. My budget is around $1100 but it's not a hard figure. With the estimated $700 for the CPU and video card, that leaves around $400 for what I hope is a decent motherboard and 2GB of RAM.
Can someone give some direction on parts that will work with everything I've got and plan to use? Am I going in the right direction for this build?
Thanks!
Thanks!
