Advice for installing wireless in an old mall?
TonyG
2,021
I have been asked to install a wireless network in an old shopping mall near me. There a about 7 people in it who would like a wireless connection to share cable internet over.
The walls between the stores are plaster with metal studs, and if I remember correctly there are no brick/concrete firewalls between the stores that want a connection.
The stores are probably within a 400ft max distance of each other, which I do not think a regular wireless router will handle. Also, most of the computers will not be within a line of site. What is the best option for going about doing this.
I am thinking that I will take the microsoft router I have up there along with a laptop and start checking the ranges I can get to get some idea of what it is inside the building.
Just looking for any advice that might be helpful.
Thanks,
TonyG
skyking
22,710
5,838
I'd look at WDS. A couple of WDS capable devices could cover that area, depending on those walls.
tvarad
1,130
I think a wireless router with a couple of repeaters would do the trick. You could increase the number of repeaters if the signal doesn't reach a particular spot.
