System Specifications:
I. Processor/CPU: Intel i5-3570k
II. Current Graphics Card: None
III. Display Resolution: 1280x1024 (See additional details)
IV. Power Supply Unit Specification:
XFX 550W PRO550W Core Edition Single Rail ATX 12V 44A 24PIN ATX Power Supply 80PLUS Bronze
V. Case Specifications:
Antec Three Hundred Two Mid Tower Gaming Case
Purchase Details:
I. Budget? Not set, see additional details for what I am trying to accomplish.
II. Any particular preferences ? None
III. Do you plan to have any Multi-GPU solutions such as Crossfire or SLI? Not at this time
IV. Have you previously looked at a product(s) which you feel would fit your needs? No
V. What are your needs for this GPU? Which games(If any)do you intend to play? If you have this information at hand, what are the desired detail levels?
Foreseeable choices: Skyrim, Diabo, Torchlight, Mass Effect, Uncharted, Batman, Max Payne, Starcraft
General likes: RTS, ActionRPG, Adventure
Generally do not play FPS.
VI. Do you plan on overclocking the card you intend to purchase? Possibly, but not at first.
Additional Notes
This is my first non web browsing only computer in 10 years. I haven't purchased any non console video games since then.
I currently have old Dell 1907fp monitor with max resolution stated above(1280x1024). I will most like upgrade to a better monitor (Budget <$150) around Christmas or New Years. I am not sure of the quality of monitor I will get for that budget, I think it may only support 1900x1200?
So my question is what card options would you recommend for the me? Something that can play max quality settings at low resolutions until I upgrade and then high to max settings at 1900x1200 or whatever my new budget monitor would be able to do.
Thanks everyone.
Purchase Details:
Additional Notes
Thanks everyone.
