1. What YOUR PC will be used for - Gaming (Diablo III, Titanfall, BF4) mostly but some streaming/watching shows/movies
2. What YOUR budget is - $1000
3. What country YOU will be buying YOUR parts from - USA - Newegg, TigerDirect
5. IF YOU have a brand preference - Intel
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are
I have these parts on hand already from previous deals
Intel 330 Series 240 GB SSD
http://www.newegg.com/Product/Produc...82E16820167127
G.Skill Ripjaws 8 GB (2x4GB)
http://www.newegg.com/Product/Produc...82E16820231428
2 TB Western Digital Caviar black from previous build, mouse + keyboard
7. IF YOU plan on overclocking or run the system at default speeds - not at the moment but will over clock in the future
8. What resolution, not monitor size, will you be using? 1920 x 1080
9. WHEN do you plan to build it? in the next month
What I have in mind:
Processor: i5 4670K $240
Motherboard: ASRock Z87 Pro3 $90
GPU: ???
PSU: Corsair HX 650W $90 AR
Case: NZXT Phantom $120
Monitor:???
Thanks
GPU: ???
Monitor:???
Thanks
