- Mar 28, 2000
- 773
- 0
- 76
I am in the market for a new CPU, and I was wondering if you guys could offer a little advice..
1. Do you guys recommend purchasing a "already tested pre-clocked Duron XXX @ XXXX" from stores such as overclockers store, or icompz"? Are they trust worthy? Are they reliable?
2. should I just buy a CPU and attempt to overclock it myself? And what CPU should I get that would offer the best stability, speed, and overclockableness? Duron 800 or TBird 1.1ghz, or... considering that a lot of the CPUs are different and have different speed limits. Which motherboard? I'm torn between the Abit KT7 and Asus A7V, both are good, one has BIOS options to change the multiplier, while the other is jumper.
3. If I overclock the CPU, does that mean that every part of the motherboard is overclocked? (ie memory, PCI/AGP slots?) So, I already have 2 128MB PC 133 (one infineon, the other nanya), would that be okay? I also have an AGP ATi Radeon AIW. BTW, how do you overclock memory and videocards?
4. I read somewhere in these forums that the lifetime of an overclocked system is a lot shorter than normal... how long is that? Basically, I just want a fairly fast (at least faster than the PIII 550mhz Celeron that I have right now) computer, and not have to worry about it too much.
5. What is CAS 2-2-2, CAS 3-3-3, etc..? and how do I change it?
Well, basically that should answer all of my questions...
thanks a lot!
thanks a lot!
