I'm thinking about upgrading to a new gaming PC and since I'm not sure if I could wait until the release of the GTX 960, I decided to see if I could scramble another potential build using the GTX 970 instead.
Since picking PC parts out is somewhat new for me, I would like a general opinion of how well this build will fare in terms of gaming in terms of how pretty I can keep the graphics while still maintaining an acceptable FPS (both old and new games) as I'm planning on keeping this for as long as possible. Furthermore, I have a couple of questions regarding the build listed at the bottom:
I should add that I'm residing outside the US and having the PC prebuilt from a certain selection of parts so my alternatives are pretty much narrowed down to the ones I've posted.
Finally, I would like to thank anybody who are reading this and willing to help. It is greatly appreciated!
CPU: Intel Core i5-4690 3.5GHz Quad-Core Processor
Motherboard: Asus Z97-P ATX LGA1150 Motherboard
Memory: Kingston Fury Black Series 8GB (2 x 4GB) DDR3-1600 Memory
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Video Card: Gainward Geforce GTX 970 Phantom 4GB Video Card
Case: Corsair Carbide 330R
Power Supply: Cooler Master 650W 80+ Bronze Certified Semi-Modular ATX Power Supply
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)
- First of all: Does the parts seem to be compatible with each other? I ran the build through PCPartsPicker and it didn't seem to come up with any issues.
- Motherboard: I picked the Asus Z97-P since it seemed like the best motherboard for a single GPU setup. My other consideration was the MSI Z97 Gaming 3 for about $47 extra and if it is better performance-wise over the Z97-P even though I'm only going to use one GPU.
- GPU: Anyone have experiences with the Gainward Geforce GTX 970 Phantom 4GB? Is it a good GTX 970 GPU? My primary concern is the performance and the temperatures since I'm not familiar with the general cooling of Gainward cards. Other alternatives might be the ASUS Geforce GTX 970 STRIX, MSI Geforce GTX 970 (non-gaming), and the Zotac Geforce GTX 970. It seems that the Gainward Phantom has the highest factory overclock of all the GPUs. Not sure how effective the cooling of it is compared to the alternatives, though.
- PSU: Anyone who has any experience with the Cooler Master G650M? I assume that the wattage is enough to handle the build even under full load. My other choices are the Corsair CX 500, Corsair CX 500M, Corsair CX 600W and Corsair CX 600M - all which are about $13 more expensive than the Cooler Master.
- Case: My primary concern is whether the build will fit inside the case and how the general alrflow/temperature management of the case is. I'm really considering switching swapping it for the Cooler Master CM 690 III which is about $9 more. Is the CM 690 III better in terms of room (making it all fit) and cooling compared to the Corsair Carbide 330R?
