imported_dawurz
Is 10 to 20% reasonable with the following?
K8N-E (presuming the lock is present and where are the damn reviews!)
Athlon 64 3400+ Newcastle 2.4Ghz/512KB L2
Thermalright SLK948U (or the not-yet-released XP-120) w/92mm
On one question for the wizards: Is Corsair TWINX1024-3200XL 2-2-2-5 1GB Kit DDR400 XMS3200 Dual-Channel Xtra-Low Latency Memory w/Black Heat Spreader a wise choice, or is an overclock possible with less expensive memory? I read here at anand about OCZ 3700EB, but read the 2-2-2-5 may work better in the 200-250 range, for a less agressive overclock (and one suited for a first-timer!), and even one suited for the K8N-E.
Many thanks for any direction and comments.
other parts planned:
WD2000JD 200GB SATA
Sonata case w/True550 & addl 120mm (sunon, panaflo, vantec - not sure yet)
audigy 2
logitec z-5300
9800XT (in hand, for now)
WD2000JD 200GB SATA
audigy 2
logitec z-5300
