I see a lot of recommendations for mid-range gaming rigs, I'd like to get some help building a nice mid-range home server. My answers to the questions:
1. What YOUR PC will be used for: 64bit VM machine used for VMWare / Microsoft server technology. Would like 8GB ram with ability to move to 16GB over time. I'm looking for as much performance in VM as possible and just on board video is fine.
2. What YOUR budget is: $500 - $900
3. What country YOU will be buying YOUR parts from: US
4. IF YOU have a brand preference: No prefs, would like to lean towards easy to setup (I haven't really built a computer since the old days).
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are: None
6. IF YOU have searched and/or read similar threads: read a couple, nothing hit home
7. IF YOU plan on overclocking or run the system at default speeds: No plans for overclock
8. WHEN do you plan to build it: This month
Need recommendations for everything, including:
Power supply
Case (Something with nice expandability, ease of use, not too large, nothing too flashy)
Motherboard (with onboard video)
CPU (Thinking multiple cores?)
Heatsink/fan for the CPU (Do I need something extra than on board?)
Memory (DDR2 or DDR3?)
Raid Controller (Would like some failover protection?)
Anything else I'm forgetting
Thanks in advance!
Power supply
Thanks in advance!
