- Mar 13, 2005
- 145
- 0
- 0
OK, I have my:
Winchester 3200+ running at 225x10 (12hr Prime95 stable, no errors) v at ~1.53
with corsair CMX512-3200C2 at 187.5 mhz 2.5/3/3/7
on an MSI K8T NEO2 FIR.
I'm positive that I can do better than this, but things start to go haywire with the RAID setup. (2x36g Raptors) If i go much higher than that, then it tells me that I have a broken array on boot. I also have 2 devices on the other 2 SATA ports, for a total of 4. I have the raptors on the VIA controller, because their performance was crap on the promise... (before OC).
Anyway, after a LOT of googling and forum reading, I'm coming to the conclusion that the SATA lock (or lack thereof) is the problem? Anyone have input? Do I need to move 2 of them to a PCI controller?
Also, i have the AGP locked at 66, can I up it to the next setting, 75.4? Would it make a difference? (have a 6600gt in that slot)
I have the RAM set at 333 in the bios... did i do this correctly? (225*.83=186.75).
I can post screenshots if it would help with any responses. You might be able to tell i am semi-noob to AMD OCing. Done lots of homework but still hitting some brick walls. Thanks for all of your input. I'd really like to sqeeze more out of this processor.
