Advice buying components 3D Art
Senderos
Hey there,
Thought I`d post here as Anandtech and the forums around here are usually swarming with people who are quite up to date regarding hardware and software as well and they pretty much know what they are talking about 🙂 .
So, I am planning on buying a CPU, Motherboard, Graphics Card and RAM.
I am a 3D Artist, working with programs like 3DSMax, Maya, Unreal Engine 4, ZBrush, Photoshop etc. My goal is to choose components that best serve my 3D work. This work is made up mostly by rendering calculations, working with scenes that handle a larger amount of texture data etc. I already have a pretty good SSD, so no need for that at the moment.
Also, I`d like to play games everyone and then, BUT by no means on 4K resolution.
Another important thing to mention is that I will be purchasing these components in the UK, so I`m looking at the best prices from http://www.pcpartpicker.co.uk
My budget is: 900-950 GPB = 1,350 - 1,400 $.
Here is what I have cooked up so far:
CPU: Intel Core i7-5820K, Haswell-E, 6 Core, LGA 2011-3
http://uk.pcpartpicker.com/part/intel-cpu-bx80648i75820k
Motherboard: MSI X99S SLI PLUS, Intel X99, S 2011-3, DDR4
http://uk.pcpartpicker.com/part/msi-motherboard-x99ssliplus
Videocard: Asus STRIX GTX970 DirectCU II OC 4GB (Maxwell)
http://uk.pcpartpicker.com/part/asus-video-card-strixgtx970dc2oc4gd5
RAM: Corsair Vengeance LPX 16GB (4 x 4GB) DDR4-2400 Memory
http://uk.pcpartpicker.com/part/corsair-memory-cmk16gx4m4a2400c14
Thanks very much!
I wouldn't choose that board, but it's up to you..
Hey Burpo, thanks for the reply. Why wouldn't you choose this one? I chose it because it was one of the cheaper X99 boards as I don't want to spend a whole lot on a motherboard, but I would definitely want to hear your advice.
Thanks again.
get 2x8GB RAM over 4x4GB any day
Thanks for the tip 🙂 . I`m buying my ASUS GTX 970 card today... I had a GTX 460 which stopped working and then I switched back to my ancient 9600GT for 1-2 months. I think the performance increase is going to be .... subtle 😀 .
