I recently contacted their support team and learned that the current version of SQL 2008 will not work with their current advantx version. They said 2005 is the latest version that it will work with. I have already purchased the 2008 version but have no opened it yet.
Should I bother even trying to try the 2008 version with the advantx or no?
They also said Server 08 32 bit is the only one that will work with the advantx version but I have successfully installed it on vista 64bit platforms and there are no errors at all so is it safe to say that they only officially support 32bit but I will be ok with the 64bit? I need 64bit because of the amount of memory that is currently going to be in use.
