diesel is usually about the same price as regular.
advantages:
gobs of torque
good mileage compared to gas engine
disadvantages:
diesel fuel not available everywhere
LOUD
stinks
Diesel fuel is widely available on every interstate.
Modern Diesels do not emit obnoxious odors.
Go for it, diesels require very little maintenance compared to gasoline engines, they do not require plugs, wires etc. for a tuneup, they tend to last a lot longer than gas engines, they will never stall when you submerge your truck in a mud bog (No high voltage ignition to short out).
As for the cold weather starting, in temps below 20 F, they do tend to gel there fuel but this handicap is easily overcome by adding a antigel supplement during fill ups ($1.50 extra per tank), if you live in a extremely cold weather enviroment you will have to plug in the engine block warmer on a nightly basis.
On a side note, aftermarket performance part suppliers now have a vast high performance parts selection to raise those HP numbers up through the roof, besides, there is nothing like torque, torque, torque when you are driving a P/U truck
What about the maintenance costs on diesel engines?
is it just oils changes and such like on regular engines or are there other maintenance issues just for diesel?
How hard are they to do 'do it yourself' type fixes
Oil, oil filter and fuel filter changes are all that is required for maintaining diesel engines.
