Antec and Enermax are both VERY good brands, although Enermax would be a little quieter
The only real advantage of a 400W over a 300W is that it can power more devices. If you only intend to run one hard drive, 3 or 4 fans etc then a 300W Antec/Enermax Psu will be ample for even a grunty Athlon system.
