Adobe Acrobat Forms Help
WileCoyote
694
I'm creating a user-editable form in Adobe. If I create a new object, like a check box, everything works except the words "Check Box" will appear in the final form next to the actual check box.
If I create a radio button, the words "Radio Button" appear next to the little button. And so on.
I've gone into the XML Source and I see:
<value>
<text>Check Box</text>
</value>
So I can delete it, one by one. But there are hundreds of these labels on the form. Is there anyway to hide/get rid of/change it so they don't appear?
