Hey all -
Got another question for you... I've been monitoring my connection (10 mbps ethernet here on campus) for awhile now and have been able to get the following transfer speeds with a few registry tweaks:
Download - ~2400 kbps average (~13 mbps max)
Upload - ~900 kbps average (~3.5 mbps max)
First off, I'm wondering how it's possible to have a higher transfer speed than the connection should allow. Also, why in the world my upload speed is so low in comparison? Is there anything I can do to adjust my ethernet settings (beyond what I can do with Dr TCP) in order to speed up my average download/upload speed? Also - is there an "optimum" RWIN that I should be running at on my connection? If so, how do I figure that out? Will running it over that number cause a performace loss? I like the max speed, but I'm almost never close to it. That's why I'd like to increase the average speed. My current registry settings are as follows:
RWIN - 256960
Windows Scaling - Yes
Time Stamping - No
Selective Acks - Yes
Path MTU Discovery - Yes
Black Hole Detection - No
Max Duplicate ACKs - 2
TTL - 64
MTU - 1500
Thanks, and let me know. Also, if any of you are doing the dorm thing as well and have a 10mbps connection, how are your speeds in comparison? Catch ya later...
- Eric
PS - Oh yeah... I'm using a Realtek RTL8139/810X Family PCI Fast Ethernet NIC (the one that came with this Alienware laptop) with the most up to date drivers available.
PPS - No, I'm not asking to how to increase the bandwidth (that would be against the rules) - just how to make the most of what I have through adjusting my own computer. After all, this is the best place for tweaking advice, right?
RWIN - 256960
Time Stamping - No
TTL - 64
MTU - 1500
- Eric
