adjustable fans?
Enermax makes some case fans that are adjustable.
The idea behind it --> keep "unnecessary" noise to a minimum...I believe they aren't actually user adjustable but there's a temperature monitor that throttles the fan speed as necessary.
Noise pollution.
When you don't need the extra cooling, for example on a cool day or when you're not fragging, you crank the rpm's down to reduce noise.
When you're in death match or it's 105F ambient, you crank the R's up for more cooling.
Edit: Enermax makes manually adjustable fans.
