Addtronics W8500 screwing problem help please?@?@?
Zilldian
105
I have the Addtronics w8500... How the heck can you get the screws in on both sides of the CD/burner/DVD drives??? The right side is facing you and easy to get to but the left is to close to the MoBo trey to do anything with..
Any comments are welcome...:confused:
Oh Ya its here
DesertFoxzz
I have two Addtronics W8500 cases and the case uses rails. You screw the drives to the rails then slide the drives in place. After they are in place you screw the rails in the front of the case.
In my cases the motherboard tray is no where near the drives. Are you sure the tray is installed right?
Zilldian
105
Thanks for awnsering back, That was the only part I didn't think of. Thankyou very much.
The MoBo trey isn't that close I just can't describe it correctly.
Thanks again.:D
