addtronics power supply and athlon xp
renfield33
218
hey all,
i have an addtronics 7890a case that i bought with the addtronics 300W power supply in 1999 (early). it is the one with no power switch on the back. the addtronics website says that all of their power supplies are athlon approved, but i was wondering if any of you have had any experiences with this power supply. i am especially worried b/c i bought that ECS motherboard that anand said was kinda finicky w/ power supplies. btw, i will be running an athlon xp 1600 w/ scsi controller, 7200 rpm drive, cdr, dvd-rom, tnt2ultra, floppy, and scsi zip drive as well. you can follow the link to my rig below. basically i am replacing the proc, mobo, and ram.
any advice would be helpful.
thanks,
spencer
darktyco
122
I have been using the same addtronics power supply for a year and a half now without a single problem. Voltages are always steady and my 1.2 T-bird @ 1.333 is as stable as can be. I highly recommend Addtronics to anyone.
