Address Bar problem, please help.
davisy2k
26
I am having a problem that just started and I don't know how. Ok here it goes, anytime i type anything into the address bar with "http://" it does not find the site I get an address bar error message that says has been disallowed. But if I remove the "http://" it works fine.
example. http://www.yahoo.com does not work but www.yahoo.com in address bar works. does anyone know what this problem could be, please help.
Thanks.
stndn
1,886
it's http://
you just missed the : colon ;)
-551-
edit: ahh... so it's not that problem then.... i dunno what's wrong but i'll post when i do
davisy2k
26
Yeah, I sorry about that .I missed the colon in my post but I do put it in my address bar. Anybody know what the problem could be.
bigshooter
2,157
why do you want to type in http:// anyways? Isn't it easier just to put the site in. I only type it in if i'm typig a url for a secure site and need to get the s in there. And are you using IE or Netscape?
davisy2k
26
<< why do you want to type in http:// anyways? >>
If I click on the arrow down key to check out a previous url's, if it has the &quot;http://&quot;,i would have to delete the &quot;http://&quot;before hitting go.
Anyways thanks for the help but the problem has been solved by reinstalling my browser (IE 5.5).
