Additional PCI-E molex power needed?
VirtualLarry
56,587
10,227
13-157-636-Z01
Do I need to connect the molex next to the PCI-E slots?
Currently have this board with a G4400 @ 4.455Ghz, and a 7950 3GB card in the top PCI-E x16 slot.
I assume that the molex to to provide +12V power to both PCI-E x16 slots, when both are occupied. So I think I'm OK with not plugging it in with only one card, correct?
Edit: The reason that I don't currently have it plugged in, is my PSU only has a single molex chain, and it's currently plugged into the front case fan, and won't really reach to the mobo.
master_shake_
6,425
292
121
no, no you don't
well...
unless there is a gpu out there that needs it...
but even a dual, dual fury-x setup wouldn't even need it.
Magic Carpet
3,477
234
@dave_the_nerd
That's what I thought. Bitcoin friendly board :)
@VirtualLarry
No need unless you going to use PCI-E riser cables to connect more GPUs.
VirtualLarry
56,587
10,227
@dave_the_nerd
@VirtualLarry
Thanks everybody! I figured it was for multiple GPUs, but I wasn't sure if it was necessary with just one.
