hey folks
i summon the infinite wisdom of anandtech (ommmm)
Added a second IDE hard drive as the slave drive.
Windows XP Pro sees it but wont' assign it a volume, so I can't access it. But it's reported as Healthy(active).
In properties, under volumes,
Disk 1,
Type Basic,
Status Online,
Partition Style: Master Boot Record (MBR),
Capacity 19461 (which is correct),
Unallocated Space 0,
Reserved Space 0.
In the volumes box, there's simply a picture of a hard drive drive symbol, no drive letter, and the correct capacity. Populate is grayed out and properties does nothing.
In disk management, it shows up under Disk 0 as a Basic, 19.00gb, Online with a healthy(active) 19gb NTFS partition, but the only options I have are properties (same as in device manager) and delete partition.
Ned to transfer data off the disk to the main drive. Can't delete partition, reformat, etc.
So what's up with this?
Disk 1,
Type Basic,
Status Online,
Reserved Space 0.
