- May 10, 2005
- 71
- 0
- 0
I have one fan blowing air into thr case in the front, one fan blowing air out in the back, and I'm going to add another fan on thr side of the case, just in the line of the CPU. Should I have the third fan blow air in or out?
By the way, my Yateloon fan (came with my case) at 1800RPM sounds like a huricane, but I found fans from Glacialtech which are supposed to push 37CFM at about 950RPM (mine is at 1030RPM most of the time, so pushing more air) and they are the quietest I've found. They don't feel like they push that much air, but the Yateloon at 1800RPM doesn't feel like it's pushing that much air either (both fans are 12cm). I thought Yateloon is the same as Nexus which is considered the quietest.
Thanks.
Thanks.
