<< BTW...maybe i shouldve put this from the start...but i got my IDE drive, installed it, and everything works fine...and just for you patrick...my performance is STILL THE SAME....its ONLY astorage drive...ok im done proving my point >>
Teejae, lighten up will you, i stated my opinion as a professional, i really do not care if you follow my advice or not, but my point WAS a valid ONE.
If you USE an IDE DRIVE for STORage, i would believe that you store your data on it. MAYBE you do not. BUT if YOU do so, then THERE will be some INTERACTION between THE drives in YOUR system, and IF the FILES you are STORING are BIG ones then an all SCSI interface would BE a better solution because you could open the files WITH less CPU interaction, this is NOT my OPINION, this is a FACT.
Patrick Palm
Am speaking for PC Resources
