- Dec 4, 2005
- 273
- 0
- 0
Hello,
I have a front fan and a rear fan on my case. The case has no side vent. I have 4 SAS controllers and a video card on that motherboard. The SAS controllers run very warm. I'm thinking I should probably get more airflow to them but there is no side vent. The cards are probably about 2.5" - 3" from the side of the case. Are there any good kits to make it easy? I have a dremel and have cut holes sheet metal before. I suppose I could drill a few holes for screws but I thought I'd see if there was anything to make the process easy. I believe it is a Compucase A6 mid tower if it matters.
