Originally posted by: Paperdoc
Originally posted by: herm0016
if you thing 2 conductor will run something like that, then you should hire it out. that is a large amount of current.
The NUMBER of conductors is not important - it's the GAUGE (size) of the conductors! Since this device does not use a neutral line, you don't need one, at least at first glance.
BUT if it requires a specific type of outlet to plug into, the outlet itself may impose a need to supply a neutral line even if your specific device does not use it.
Best advice in this thread is from BigJ. He / she points out there are particular code requirements you do not know about; moreover, you clearly do not understand how to find the right info for your relatively simple initial question. And you haven't even thought about which type of cable you need, which depends on weather exposure, temperature extremes, physical exposure or protection of the cable, etc. Ask a pro!
In this case they are talking about the number of discrete conductors required to run the device, not the number of strands that make up the wire.
Two hots, one neutral, and one ground are what you would find in a piece of three conductor romex. The ground isn't counted because it's not normally a conductor.
