Add System Rig --- Fixed!
ohnnyj
1,239
Hello all:
I posted a while back about not being able to add my rig and someone tipped me that it may be one of the fields stopping it from going through. So I proceeded to fill all of them in and delete each entry until I found the culprit.
I didn't take to long as it turned out to be the last field, the Notes field. So FYI for all of those having trouble adding their computer, simply don't fill in the Notes field.
Maybe a fix will be implemented when time permits?
Jeff7181
18,368
11
I was wondering about that. It kept saying the error was logged so I figured someone here would notice it and get on top of it.
*EDIT* I just tried again and got the error again, so leaving the Notes field blank doesn't necessarily fix it. It must be something else.
ProviaFan
14,993
It used to be that you couldn't fill in the CPU overclock speed field without an error, but I don't know if that's still the case. Regardless of which field it is, the system rig thing has had this problem for [a very long time], and needs to be fixed.
ohnnyj
1,239
Sorry it did not work, just try filling in all the necessary ones and then hit the submit and see if it works. I think you can edit the rig later anyways.
bjc112
11,460
Errored out for me as well..
Typed in it about 3 different times now..
Just going to type it in the sig!
:p
Jason Clark
I know guys, its going to be addressed in the next update im doing in a few weeks. I know it's a PITA, time is limited.
