Add/Remove Program Access Problem, Please Help
HansG
I'm having difficulty getting the add/remove program to come up in the control panel. When I double click to access it, it just stays where it says "please wait while the list is being populated". It always came up pretty quick but no more. I hit the task manager and CPU resources are less than 3% so there appears to be nothing bogging the PC down. Any ideas?
Thanks,
Hans
Thanks, my current them is "Windows XP". As far as the uninstaller goes, what are you referencing? When I uninstall a program, I go through the add/remove programs. Is there a better way?
Thanks,
Hans
