hey all,
i've exhausted all of my options here so I turn to the experts.
using Windows XP Pro, and I have a SIIG Ultra ATA/133 PCI Bus Master host controller (model
SC-PE4B12), and it's not recognizing that there's anything connected to it.
It won't let me hit F3 to setup either (on POST, the card's BIOS shows nothing connected to any of the 4 channels). I've tried with both F LOCK on and off.
HD is set as master (also set it as slave with no luck).
Tried 2 different IDE cables (both new) without luck.
I have SIIG's drivers installed properly.
Thought it might be the HD, so I set it up on its own IDE cable and it's recognized fine.
I have an Asus P4C800-E Deluxe and even tried setting it up on the onboard Promise RAID controller (setting it to IDE in the BIOS), with no luck.
Is there something in the BIOS I need to be setting that I'm overlooking that I haven't turned on?
I got the card from a friend and it was working fine in that system.
Thanks for any help.
